Random Material Assignment Script
Started by TpwUK, June 03, 2016, 09:35:17 AM
Still working on the script, sadly it looks as if have to hard code materials into it, so looking forward to the day when we can walk the materials library like we can the scene tree through script. But as you can see it works fine. It's been tested with a scene with over 5,000 parts and it works as expected. When i get some materials I can share with the script i will post in the scripts forum. In the mean time it would be great to get some feedback as to whether you think it has any value to your workflow :)
mertmg
I'm a touch confused, so you're choosing a set of materials to be applied to a scene full of parts? The 'random' part is which material gets applied to which geometry? Am I understanding this correctly? It sounds cool.
Quote from: Will Gibbons on June 10, 2016, 12:01:32 PM
Yes - you are understanding it correctly. Blender, Max and C4D all have floor generators to use, but you can end up with hundreds or thousands of parts (tiles or planks), so create a family of textures with different grains or patterns and then randomly apply to each part of the floor. It's surprisingly very few lines pf code but it works. The only downside at the moment is that the material family has to be hard coded, such as Ash #1, Ash #2, Ash #3 etc
Quote from: TpwUK on June 10, 2016, 12:32:33 PM
That makes sense. Does your method give you more control than using a material template?
QuoteThat makes sense. Does your method give you more control than using a material template?
I have no idea Will, never used templates. I have been delaying putting the script up because I have been waiting for some people to offer some quality textures to go with it, but none seem to be forthcoming so i will finish off a family of antique beech wood textures i threw together hopefully over the weekend and i will put the script up with those and you will be able to test it for yourself.
Quote from: TpwUK on June 17, 2016, 03:23:20 PM
Awesome, I haven't used them a bunch myself, but was just curious.
