Author Topic: Modification of an existing animation with Keyshot  (Read 2694 times)
Offline Sebac_86
« on: June 27, 2016, 04:16:50 am »
Hi all,
I've been working on the animation video of a product last weekend. After I got the final results, I would like to modify and improve a little part of the animation related to the fading of some parts.
Since the rendering took me 3 days, I would like to render again ONLY the part I would like to change, and not the entire animation.
Is it possible to render and replace the new frames with the old ones, and make the entire video again??
Any suggestion  how can I change only one part of the render animation without rendering the entire video again??
Offline Robb63
Re: Modification of an existing animation with Keyshot
« Reply #1 on: June 27, 2016, 06:19:45 am »
In the animation tab of the render window, where you setup the parameters for the animation (output size, video checkbox, etc...), you can choose to render a frame range. This should allow you to re-animate only the frames you need.
Offline Sebac_86
« Reply #2 on: June 28, 2016, 05:36:46 am »
Is it possible to produce a new animation video with the new frames (corrections), without rendering the entire animation again??
Thanks for answering.
  • Guest
« Reply #3 on: June 28, 2016, 07:22:22 am »
You will need to use a 3rd party application in order to compile all the frames into a movie file.
Offline Sebac_86
« Reply #4 on: June 29, 2016, 12:33:05 am »
OK, thanks!
