In the leaf image background should be transparent, but it looks black
Started by Zvi, July 03, 2016, 02:03:12 AM
Zvi
I use models of a trees with leaves, which each leaf  is a picture of a leaf. In the leaf image background should be transparent, but it looks black, as shown in the attached image.
willchocks7
increase your 'ray bounces' in lighting settings.
If that doesn't work then you need to make sure that you're using an opacity map. Change the material type to 'Advanced' and insert an opacity map. If your leaf texture has an alpha channel, then just check 'use alpha from diffuse' in the material properties.
Zvi
