Author Topic: strange effect appearing while using fade animation  (Read 4666 times)
Offline kubafootbag
« on: July 16, 2016, 02:59:33 am »
Hello everyone,
Today I tried to render simple animation using combined fade animation with movement of other parts. I did not expect any problems there but suddenly I noticed some square-shape shadow appearing on the ground.
Please see the link below:
https://youtu.be/Y9rprtSQ6GQ
Do you have any idea how to get rid of this strange effect? why has it happened like this?
Thank you,
Kuba
Offline TpwUK
Re: strange effect appearing while using fade animation
« Reply #1 on: July 16, 2016, 04:07:36 am »
Looks like you need a ground plane adding - Why you're seeing the square shape i have no idea.
Offline LayC42
« Reply #2 on: July 17, 2016, 05:08:22 am »
 these strange squares appears if the ground size is too large.
A ground plane (edit -> add geometry -> ground plane) will solve this problem.
And then as render settings max samples mode will render every frame with the same quality.
« Last Edit: July 17, 2016, 05:11:53 am by LayC42 »
Offline kubafootbag
« Reply #3 on: July 17, 2016, 11:18:25 am »
Thank you guys for your replies.
Actually, I have added ground plane already. I tried to change its size but nothing changed, squared size shadow is still there. I rendered animation using max samples option, it didn't help.
Any other ideas? I am quite sure it's coused by fading option, while changing opacity either to 0 or to 100% everything is ok...
Offline HaroldL
« Reply #4 on: July 18, 2016, 07:40:35 pm »
I found the model on GrabCad and created a Fade animation similar to yours. I did not see any of the square shadowing that you experienced. I even tried with every HDRI to see if that would make any difference. It didn't.
What format did you use STEP or IGES? I down loaded the model in STEP format. I might try the IGES and see what happens with it, though I don't know why the format would make any difference. ???
  • Guest
« Reply #5 on: July 19, 2016, 07:39:47 am »
The file format has nothing to do with it because it is converted to polygons upon import.
Any chance you can share the scene?
Offline kubafootbag
« Reply #6 on: July 19, 2016, 08:47:00 am »
The scene itself is just imported model (in fact, it is from GrabCAD, I imported STEP file) and added groundplane. I applied some materials in standard overhead array_2k enviroment.
Any other ideas what's wrong here?
Offline Chad Holton
« Reply #7 on: July 19, 2016, 09:32:17 am »
What version are you using exactly (e.g. 5.1.234)? Please send the scene to: [email protected]
Offline kubafootbag
« Reply #8 on: July 20, 2016, 04:26:59 am »
Thank you guys for the support. Honestly, I don't have time to go deeper into it, I give up. I changed scenario and now housing is fading down to 0% and everything's all right. Maybe there's something wrong with model, hard to say. I use 6.0264 version.
  • Guest
« Reply #9 on: July 20, 2016, 07:25:46 am »
Please make sure to update to the latest version of KeyShot. Build 6.2.105 was posted  today.
