TpwUK's wish list :)
Started by TpwUK, July 29, 2016, 02:24:28 PM
1. The ability to multi select materials with the material graph add texture node function, I know we can D&D from the finder window but that only works if all your materials are all in separate directories/folders
2. Render as RAW format so we can get control of exposure either in KS or with 3rd party post tools :)
3. A tick box for Snap To Ground, this way your model part can be imported and tested at floor level and then uncheck the box to have the part return to its modelled point of origin.
4. A camera that can actually zoom so we can get some proper macro type shots - As in when using DOF the focus distance should stay constant and you should still be able to zoom/focus in without it messing up the distance between lens and object.
All the best Guys
