Color generator
Started by DougRattmann, August 15, 2016, 12:50:16 PM
DougRattmann
I think it's a cool idea 8) In order to do well
[vimeo]https://vimeo.com/170848472[/vimeo]
Can you clarify or elaborate?
soren
Do I understand you correctly as follows: You want a node where you can specify any number of colors and these colors are picked randomly based on e.g. object name, id or some other property?
Søren
Quote from: Søren on August 15, 2016, 11:23:58 PM
Søren
I am not sure what he wants either Søren, however if i am interpreting this correctly then I think he wants a node where you can choose from the Colours Library and to be able scroll through them on the fly with each colour linked to an object updating accordingly. I guess he wants a quick way of assigning material colours to see which ones suit the model/design.
Could be handy especially if it was like a sticky node that remained the same across each colour/material assignment via the material graph editor.
Seems like the request is for a random color scheme (palette) generator as a node. Like this or this.
And then each color swatch should have a distinct output channel? And the different colors/channels should be mappable to the input channels of different materials?
DougRattmann
#5
Friends, it is very difficult to express their thoughts, since I do not know much English! But you all understand correctly!
I think it would be great to use a ready-made color schemes and using an algorithm to impose them on the already created objects.
Quote from: DriesV on August 16, 2016, 02:01:10 AM
That's right! The video was used as the source of the color palette with dribbble site, but you can try to make file upload .ico already has a color
