bug, jumping frames
Started by PeterSwift, August 19, 2016, 10:47:15 AM
PeterSwift
Have anyone encountered a bug like this one?
After numerous  renders for some reason my animation started to bug out.  Everything looks normal in Keyshot but when I have render out everything in frames and looking at it.   every 5/6 or 7th frame the model jumps a bit.      So to explain a little better.
After 5 frames. In that frame the model have move up a little, next frame it continues as normal, 6 frames later, jumps up a little, then continuous normal, 7 frames later jumps up a bit then continuous as normal. Then 6 frames, 5 frames, 6 frames, 7 frames later.  Its a structure to the chaos.
PeterSwift
#1
And for now I fix it by locking all layers,cameras,animations.
Edit.
Im starting to think the network render that is the problem.
