Network Rendering View Settings of a Queued Item
Started by DMerz III, September 13, 2016, 08:41:25 AM
DMerz III
Would be totally awesome if there were a bit more information available once an item is in the queue on network rendering.
For instance. I had sent several 'jobs' from a particular file to the queue, but once up there. I noticed I may or may not have adjusted a particular value in the settings (in this case, it was DPI). I wanted to make sure I had 300dpi instead of 150.
However, once the job is in the queue, there's really no way for me to check to see what those settings would have been when I sent. Including all the render settings, would be amazing.
If there were a way to log those settings and make them view-able in the queue, that'd be a blessing.
Rex
Thanks for the feedback. We are working on an entire NR UI overhaul for KeyShot 7 including the ability to modify and "resend" jobs
DMerz III
Thanks for the update Rex, I'm very glad to hear that! Let me know if you guys need more input on NR stuff, we use it everyday!
