Green & purple marks Render
Started by Blitz, September 25, 2016, 04:30:17 AM
Blitz
I use Keyshot 6 for my renders and while i am rendering, i see a green mark which also stays after my render has finished.
When my render has finished it switches to purple and stays like that. I assume these are dead pixels?
My Keyshot render also crashes at 10% when i hit 2 hours for render settings. I am not sure if these two problems has something common with each other. I can only render below the 2 hours or above the 2 hours, very weird.
I also attached a screenshot from my scene so you can see it to.
I couldn't find any topic which has the same issue as i have, so i started a new topic, feel free to correct me if i am wrong.
With kind regards,
Blitz
That is very odd. What version of 6 are you using exactly? You can find this under Help>About.
Also, would you be able to share the scene? If so, please send to: support@luxion.com
