Import CREO Assembly with parts with multiple materials on surfaces
Started by 9colai, September 30, 2016, 01:28:38 AM
9colai
Hi
I'm trying to import a CREO 3.0 assembly file, with multiple materials on part level, into Keyshot, but I'm only able to change the material for the whole parts in the import and not on the surfaces on the parts. I tried with a part file and it works just fine, but it doesn't work with the assembly file.
Do i have to use some special kind of setting when i import the assembly file in order to make it work?
Best regards
Nicolai
9colai
Are the surfaces linked in KeyShot?
Also, are you the creo user?
9colai
Quote from: Chad Holton on October 01, 2016, 11:52:26 AM
No there is only one feature per part in Keyshot, and yes I'm the CREO user.
Okay, just tested and worked fine for me. When importing, try using "Group by Material" and use "Separate Materials by Part".  Also, the plugin may be worth trying as well: https://www.keyshot.com/downloads/plugins/
9colai
I think it's some kind of bug, because i tried it with another assembly and it was working fine there. But thanks for the help! :-)
