Selectively turn off cast shadows for floating geometry.
Started by OccultMonk, October 16, 2016, 10:16:50 AM
OccultMonk
Is there a way to turn off cast shadows for certain objects? I use a lot of floating geometry for example for indented screws. This is "faked" geometry, so these objects should not cast shadows. This is a very important feature to me.
LayC42
IMHO it can be quickly solved with two renders (shadows on / off) and then use a graphic tool with two layers and some mask or eraser work.
quick and dirty.
bdesign
Hey OccultMonk-
I've got a Material Graph node network for toggling cast shadows on/off. Check out my forum post here: https://www.keyshot.com/forum/index.php?topic=13052.0 (reply #3).
Eric
LayC42
Okay Eric, you're right. I forgot the surface backside mask. That would help.
OccultMonk
Quote from: bdesign on October 16, 2016, 11:16:59 AM
Hey OccultMonk-
Eric
Does that only work for area lights or also HDRI? I tried it but it does not seem to affect HDRI shadows.
bdesign
Yes, it should affect HDRI shadows if set up correctly.
Eric
