Keyshot Frame Range
Started by multitech, November 02, 2016, 05:43:30 AM
multitech
Hi Guys,
I noticed on the latest version of KS 6.2.105 Pro that when I animate a Work Area of frames, it is showing the Entire Duration frame number for the ending frame on the render output window.  For instance, I'm animating a 3 second clip out of a 10 second animation and my end frame shows 301 not 91 on the render output window.  I could have sworn previous versions of Keyshot would display the correctly ending frame number if you selected Work Area or Frame Range.
Mike
Have you adjusted the working area in the timeline?
