Slow VR on Safari
Started by nuarle, November 09, 2016, 09:16:47 PM
nuarle
I'm using several VRs on my page to show a series of models I've created that I pretend to deliver for free, I've tried the page with several browsers and althought it is faster to load in some cases than in others, in every single one it works like a charm, except for Safari, in that specific case the VR is really slow, it doesn't look fluid but just in that case.
I'm using square space for my page and the VRs are stored in my public folder in dropbox, at first I thought that was the problem but now that I've tried with the other browsers I'm not sure about it, on the other hand I've checked the keyshot site which contains some VRs and there everything works fine; but i don't know why. Any idea?
If you want to watch it you can go to www.complexgeometry.org/3dmodels
the site is still under construction so you will be asked to access as a visitor.
Thanks in advance.
Artur
maybe to much information for the browser to handle?
Josh3D
Yeah, you've got a lot of information loading on that page. Even after they're all loaded some computers/browsers may not process all of that very fast.
Imo, you could present a better experience if you either 1) use the 'download on interaction' option to make them load when the viewer clicks it or 2) link an image to a page/popup of a larger VR that can be zoomed in/out.
For that size image, I would also suggest reducing the size of the loading gif.
Hope this helps.
