Keyshot Icons Way Too Small
Started by perezei, November 30, 2016, 07:10:30 PM
perezei
Hey everyone,
I recently purchased a Razer Blade Stealth with the 4K display. As soon as I opened up Keyshot I saw that the icons were extremely small and could barely be seen. I tried changing the resolution on my computer but it only makes things fuzzy in Keyshot. Therefore I was wondering is there any way to change this within Keyshot?
Thank you
DMerz III
#1
Haha, I know exactly what you mean.
;) you'll eventually get used to it, and when you switch back to lower resolution monitor, you'll gawk at how ENORMOUS the icons are.
That being said, I do not know of a way to customize the size of the UI elements in Keyshot, however, under Windows Control Panel, display settings, you can change the settings to display type and elements to be 125% or 150% larger. This requires you to log off and log back in, but will effectively scale everything (including the elements in Keyshot) up and down. Personally, 125% is what I use. Note; this will change your desktop icons and type as well. Try it out!
This will be addressed in KeyShot 7.
