Depth Of Field Issues....
Started by rjpd, December 02, 2016, 06:40:20 AM
rjpd
Got an issue where when you try to use the Depth of Field tool in camera settings the image is always blurred completely so you can't see the geometry.
It has worked previously in this file which makes it strange. Are there some settings that I may have accidentally changed that is preventing the camera from fixing on a particular area of the geometry in the render?
richardfunnell
With 6.2 KeyShot should automatically use the "Look at" point as your Point of Focus. Make sure this value is reasonable for your scene, since that slider respects scene units. For example, if your camera is 300mm from the Look at point (which is the distance slider under Position & Orientation), then your Focus distance should be somewhat close to that.
Also, make sure to adjust your F-stop slider to a larger value than the slider allows, you can input a number up to 256 for this field.
Hope this helps.
