Where has center and fit part gone from groupings...?
Started by guest83783, December 02, 2016, 07:27:15 AM
guest83783
Hi Guys,
In Keyshot 5 you can select a group and centre and fit the group including all the sub objects.  But in V6 you can only do that with the sub objects but not the the grouping.
As an example, if I select three objects and make a group I can't centre and fit the group.  If I make another group, within the group...  I can centre and fit the objects together.
Please can you revert this to the V5 setup?
It would be handy if we didn't have to group things in order to centre and fit them all - what's the reason why you can't highlight several object and centralise them using the volume centroid of the whole group?
Andy
This is still working in KeyShot 6. I just create a group with several parts, selected the group, and then right clicked in the scene and selected "center and fit selection".
