Fluid simulation
Started by Hawks89, December 12, 2016, 05:31:51 PM
Hawks89
Is it possible to add fluid simulation to an animation? Do you have to import it from something like Blender? Thanks in advance.
Artur
You have to make the fluid animation in a third party software and export in Alembic format.
Best of luck.
In KeyShot 6 you will need to write out an OBJ sequence which you then import and render via a script.
In KeyShot 7 you will be able to import these animations natively using the C4D, Maya, 3DSMax, FBX and Alembic format.
Artur
Quote from: thomasteger on December 13, 2016, 06:43:29 AM
Hi Thomas,
When will KS7 be released?
