Rhino Worksession files won't be exported to Keyshot?
Started by octav1an, January 20, 2017, 05:15:46 AM
octav1an
So I was having this issue for some time now, when I have a worksession in Rhino where several rhino files are attached to the worksession, the geometry from other than the active file won't be exported to Keyshot. Is there something else I can do except select all, copy, paste in the active file and render?
Thank you.
octav1an
If someone will have the same problem in the future, here are two python scripts I wrote to export and update geometry. They will temporary copy all the visible geometry from the attached files maintaining the layers hierarchy , send it to Keyshot  and remove the copy.
https://www.dropbox.com/sh/7calfo832ibknwt/AADMrqKNqcHOn1fySKiGvy_la?dl=0
