Author Topic: Rhino Worksession files won't be exported to Keyshot?  (Read 2689 times)
Offline octav1an
« on: January 20, 2017, 05:15:46 am »
So I was having this issue for some time now, when I have a worksession in Rhino where several rhino files are attached to the worksession, the geometry from other than the active file won't be exported to Keyshot. Is there something else I can do except select all, copy, paste in the active file and render?
Thank you.
Offline octav1an
Re: Rhino Worksession files won't be exported to Keyshot?
« Reply #1 on: February 20, 2017, 09:08:56 am »
If someone will have the same problem in the future, here are two python scripts I wrote to export and update geometry. They will temporary copy all the visible geometry from the attached files maintaining the layers hierarchy , send it to Keyshot  and remove the copy.
https://www.dropbox.com/sh/7calfo832ibknwt/AADMrqKNqcHOn1fySKiGvy_la?dl=0
