Not getting separate materials for rendering
Started by Brett, January 24, 2017, 10:42:07 AM
Brett
Hi I have a problem with bringing materials into Keyshot via the bridge from Zbrush.
I have brought several pieces of geometry into Zbrush as STLs.
Set things up together all as separate subltools.
However its not bringing them into Keyshot separately so that I can apply various materials as needed.
Can anyone help me rectify this problem ?
Really need to get this solved
Esben Oxholm
Hi.
I don't know what can be done in Zbrush, but in KeyShot you can do the following:
1. If you just need different materials for your three parts in your scene tree, then you can right-click on an object in the real-time view and click 'unlink material'. Now, that material can be adjusted separately.
2. If you need to split up the model even further you can use the geometry editor for that. Right-click on the object you want to split and choose 'edit geometry'.
Here's a quick introduction to the geometry editor if that is new to you:
https://www.youtube.com/watch?v=N2IGoUPY90A&t=3s
