Using same bitmap for color and bump. Possible?
Started by Esben Oxholm, January 26, 2017, 08:27:02 AM
Esben Oxholm
Hi guys.
Whenever I try to use a bitmap as input for both color and bump, the color information dies.
To get the result I'm after I have to copy the bitmap.
Works fine when using a procedural texture.
Is it possible somehow to use the same bitmap for both?
Best,
Without opening the material graph open the texture tab, and simply drag the texture from the color texture onto bump texture by holding down the CTRL (ALT Mac)  key.
Let us know if that works.
Esben Oxholm
Quote from: thomasteger on January 26, 2017, 11:19:51 AM
Thanks, Thomas.
By using the method you describe, the color information is kept, but when opening the graph afterwards it shows that is has created a copy of the bitmap. Just like I had to when I did it 'manually'.
This is not a big deal, would just be nice to be able to use the same bitmap input without copying :)
I just heard that it was already done for KeyShot 7.
Esben Oxholm
