Tàndem Ramon Casas
Started by nachoriesco, February 07, 2017, 05:12:24 AM
nachoriesco
This is a 3D Printing project which I had the honor to work on, the 3D reproduction of the painting of the Catalan modernist painter Ramon Casas (Barcelona, 1866-1932) "Tandem" . Was a big chalenge to catch the original mood of the painting, being true to its style
Original Painting: http://www.epdlp.com/cuadro.php?id=144
Will be reproduced on 3D Printing
Mud material is available in the Keyshot Cloud  ;)
Better res and more views here: https://www.artstation.com/artwork/OBykv
NM-92
This looks awesome Nacho. One of your best works up to date IMO. The detail both in the sculpt and in the material is astonishing. Great great work.
bdesign
Great work, Nacho! +1 with Nico on this being one of your best. Your sculpting skills are very classical, and your lighting setups always look so photographically realistic. Do you use combinations of HDRI and physical lights?
Cheers,
Eric
nachoriesco
Thanks NM-92 Details on the sculpt were a bit limited for the 3d printing resolution and resin casting, but I'm quite happy with the results, here you can see an example:
nachoriesco
Thanks Eric!
Nico?? what you mean?. Yes I used to combine HDRI and physical lights on most of my renders
bdesign
Quote from: nachoriesco on February 07, 2017, 07:35:02 AM
Thanks Eric!
Nico is @NM-92 :)
nachoriesco
NM-92
nachoriesco
Andrzej Orzecki
Top class!
Really beautiful work with amazing details. Right now you have a new fan:P
Have you ever tried sculptures in plasticine?
Regards!
nachoriesco
Thanks Andrzej!! Yes I made several plasticine sculptures long time ago
Neat!  I'm shopping for a high res 3D printer.  What did you print your guy on?  I've almost narrowed my search to the Formlab Form2 printer.
nachoriesco
Hi Bill, this Project was printed with a Solus3D http://www.reify-3d.com/ It's a great printer for small and médium scales with a high resulotion, up to 10 microns on Z axis. If you need to print big figures or pieces the Form2 is a better choice
I think this is great Nacho - These last few posts show that you are not only a super ring/jewellery designer but that you are a very capable 3D generalist too. It's so good to see  these changes and it gives me a whole new perspective on you and your work!
pizzalover2
Quote from: nachoriesco on February 07, 2017, 07:33:18 AM
Wow, I nerver thought you can print such detailed models with a 3D printer. Amazing times!
I thought all prints have this quality:
