Burned Wood Stamp (Updated)
Started by bdesign, February 16, 2017, 12:31:01 AM
bdesign
Quote from: TpwUK on February 16, 2017, 03:41:39 AM
KeyShot branding as never seen before! - Awesome result Eric, it's even got that little indentation as was requested. A truly great effort!
Thank you very kindly, Martin! Your comments are much appreciated :)
Cheers,
Eric
LayC42
great solution!
If the material graph is getting bigger, you need a video to show instead of a screen grab. ;o)
awesome work!
bdesign
bdesign
Quote from: Will Gibbons on February 16, 2017, 07:17:16 AM
Nice! Turned out well.
Thanks, Will! Much appreciated :)
Cheers,
Eric
bdesign
Quote from: Josh Mings on February 16, 2017, 10:32:13 AM
Yeah, this looks great man. Very cool effect.
Thanks very much, Josh!  8)
Cheers,
Eric
bdesign
Quote from: LayC42 on February 16, 2017, 11:14:01 AM
great solution!
awesome work!
Thanks a lot, Marco! Yeah, I've been thinking about trying to put together a setup for recording some video tutorials. We'll see...
Cheers,
Eric
DMerz III
BDesign = The Michelangelo of Material Graphs.
Well done sir, applause!
Despot
Super, super cool Eric,  now if only KS had displacement...
bdesign
Quote from: dmerziii on February 16, 2017, 11:52:19 AM
Wow...that's quite a compliment :) Thanks, David! I really appreciate the kind words.
Cheers,
Eric
bdesign
Quote from: Despot on February 16, 2017, 12:22:44 PM
Thanks so much, John! Always great to hear from you. Yes, displacement would be so awesome :)
Cheers,
Eric
designgestalt
hello Eric,
thanks a bunch for your help!
amazing shot !!
can you explain roughly, a bit about your material graph?
I am a noob and it would be helpful just to get a rough idea... !
thanks a lot
best regards
designgestalt
bdesign
Here's a revised, more "shopworn" version of the material. I distressed the edges of the lettering a bit and added some scratches to the wood surface. Gave the wood a more raw appearance and decreased the IOR of the stamped area to make it look a bit more burned. Added a bit of dust. Cropped a bit tighter and rendered at 3K.
Cheers,
Eric
NM-92
Masterpiece ! It looks really awesome now Eric.
bdesign
Quote from: NM-92 on February 17, 2017, 12:00:18 PM
Thank you Sir! I really appreciate your kind compliment, Nico :)
Cheers,
Eric
TGS808
I thought the first one was good but that second one is perfection.
