Caustics: Physical lights shining through bottles
Started by cereal, February 22, 2017, 11:01:13 AM
cereal
Hello Community!
I'm having issues with properly setting up a lighting scene.
Down below is a screenshot from the Real-Time Render after 1 hour.
My idea was to produce caustics from these bottles with a lightbulb in the middle of this "ring" and onto the wall behind it.
I tried different setting: caustics enables; interior mode enable; increased the samples of the wall, the bottles and the lights, used primitives as a geometry for the light bulb, build a room...etc.
Maybe i'm just to blind to see the mistake..but i hope some of you can might help me out :)
The ksp-file is attached
Thanks in advance
best regards
Alex
Edit: just found one dumb mistake. my lighting-primitive surprisingly moved and wasn't in the center anymore.
Im just gonna let it bake for a while now
Looks like it is working. Let's see what it looks like after a bit.
cereal
Still not what i want. I did the region render with max. samples at 500
You may need to increase the number of ray bounces.
LayC42
I would try to use another material for the bottles. What type did you use?
DMerz III
If you're using solid glass shader, check your color input. If you have a value that isn't 100, you'll get darker than expected results. If you want dark green glass, try picking a lighter green color to start (with 100% white value), and play with the density slider to get darker tones. (hint, lower numbers gives you 'darker' appearance, in order to 'thin' out the color, increase the density number, it works a bit backwards from your expectation).
Maybe that'll help?
cereal
Increasing the ray bounces helped a lot! Thanks Thomas!
I used a white refractive glass from the library.
I tried using the solid glass, took a light green color, changed the density and as soon as i increase the samples..keyshot crashes..every time :/
I can't reproduce the crash. Will look into it further.
Solid glass gives better results for sure.
cereal
If I go above 110 samples with the solid glass, Keyshot crashes.
I'm using 250 samples for the box and the lights
But I'm getting there now. Still 500 samples. The upper part is just a matter of time and max. samples, right?
Where are you setting the samples? On the material level?
cereal
#10
Yes within the material settings.
And i used 500 samples as maximum quality.
There is no point in cranking up the material samples if you use max samples for your final render output.
cereal
Quote from: thomasteger on February 24, 2017, 03:02:13 PM
Youre absolutely right! It just gives me a better image of how the final render can look like.
Heres the last rendering i did. Used 900 samples as the final output
DMerz III
I saw recently on another post here that using the 'interior' mode with caustics will help clean up a lot of the noise quicker than without.
Have you given that a shot yet?
cereal
