Car Shredders & other Industrial Equipment
Started by azonicbruce, January 26, 2011, 06:05:28 PM
azonicbruce
A few of the projects I worked on last year with KeyShot 1.9. Can't wait to get going with KeyShot 2!
tvanryn
What kind of memory usage are you seeing with your large models?
azonicbruce
Quote from: tvanryn on January 26, 2011, 06:50:44 PM
Here is what I'm getting for that first image/model, which is probably the largest one I have right now:
KeyShots says 11236392 Triangles.
EGON
Speedster
Nice!  I really like the lighting for this kind of imaging.  What HDR did you use?  Keep posting!
boogie
azonicbruce
Thanks guys. I'm using the LightStudio Jewelery Soft Spots environment. Here is a quick shot in the new KeyShot 2 version I finally got:
Quick question. It looks like the "effects" that you can turn on under the realitime tab don't come out when you do a regular render. Is this only available in realtime, or is there a setting I'm missing somewhere?
JeffM
Should all match up just fine... Did you do anything other than the standard "render" option? Offline? Queue?
You are on 2.1.25?
azonicbruce
JeffM
Thanks Bruce, we'll try to reproduce on our end.
jhiker
Quote from: azonicbruce on January 29, 2011, 11:27:26 AM
Is that a snapshot or a render - my initial thought on seeing the picture for the first time was that it had 'bloom' applied.
