Author Topic: Patina Metal  (Read 3982 times)
Offline Kranda
Patina Metal
« on: March 01, 2017, 04:04:57 pm »
I am looking to apply a patina texture similar to the below picture to basically a cube. When I try and apply similar textures to large flat surfaces they don't look very good.  I'm guessing it is because the materials are using a curvature material to generate an opacity map to map the patina vs the metal color. I thought of a workaround by exporting a UV of the cube shape and manually creating a mask for the image. If anyone has a better idea for quickly doing this let me know.
Example of patina metal on a complicated model
http://imgur.com/a/QABBy
What a cube looks like with a similar texture applied
Offline Will Gibbons
Re: Patina Metal
« Reply #1 on: March 03, 2017, 07:18:54 am »
I'd tackle this by starting with a bump texture... then using either curvature or occlusion (as opacity as you mentioned) to show the underlying metal material.
