Rendering comes out different than on KS screen
Started by Nick, March 10, 2017, 05:44:59 AM
Nick
Hi
Windows 7, 64 bit
KeyShot 5, 64
Model from Solidworks 2012 x64
This is a problem with ALL models I use. I ready the KS model, adjust lighting and color, hit Render:  At the end, the rendering looks different from what I have on the KS screen, example:
Lighting background turns into 100% white background
There seems to be brighter lighting, many parts are "washed out" from excess light
How can the rendering look different than what I have on screen?
Thank you
Hard to tell what is going on. Can you share a scene?
Also, you are running KeyShot 5 which is a couple of years old. Did you just now notice that?
Nick
Thanks.  Attached 2 images.
A) screenshot from my KS screen
B) Rendering:  The vignetting dissappeared and it shows a white background instead
Maybe it is time to install a new version of KS...
Niko Planke
Hello Nick,
Do you by chance have include alpha enabled in the Render dialog->Output ?
Also Image A does not seem to be uploaded.
Please also provide the render-settings you use.
jhiker
Did you let the render finish - I think it applies the vignette at the end of the render.
