Medieval Ring
Started by Bernardo Lickfold, March 11, 2017, 06:08:13 AM
Bernardo Lickfold
Weekend exploration in keyshot.
Model from https://grabcad.com/
Feel free to give your comments or suggestions!  ;D
keyboop
no suggestion, it's perfect !
Magnus Skogsfjord
Materials looks great! Good job!
For improvement I would experiment with the composition. Maybe give the ring some breathing space to the right and on top. I also think experimenting with some depth of field could improve it a bit :)
Esben Oxholm
Quote from: Magnus Skogsfjord on March 11, 2017, 11:50:30 AM
+1 to that. I would crop away a bit of the bottom and move the ring a tad to the left. Would help a lot :)
Bernardo Lickfold
Quote from: keyboop on March 11, 2017, 11:43:34 AM
Wow ! Thanks keyboop  :o
Thanks for the suggestions Magnus!! I hope the new render is what you expected.
Quote from: Esben Oxholm on March 11, 2017, 01:03:26 PM
Thanks for the help Esben. I used your last tutorial on YouTube as a reference. Thank you alot for that
Here is the update. I hope you like it guys!
Very cool! Only thought is that making those boar's heads at that scale would be insanely impressive, especially in Medival times. Cool material work!
Bernardo Lickfold
Quote from: Will Gibbons on March 13, 2017, 07:11:57 AM
Yeah! I guess you're right. I had not thought about that.
Thanks for the feedback Will.
Josh3D
Nice work Bernardo! I would suggest checking out Nacho Riesco's work on the forum. He uses the occlusion for some great appearances with rings like this.
Bernardo Lickfold
Quote from: Josh Mings on March 14, 2017, 02:38:34 PM
Thanks for the tip Josh! I will check that out.
