How to add some flare to multiple frames
Started by Chad Holton, January 30, 2011, 06:25:19 PM
Hello fellow Keyshooters,
If anyone is interested, this is an easy way to add a little razzle dazzle to your turntable rendering (or single frame if you like).
-First download Blender from here: http://www.blender.org/download/get-256-beta/
-Check out my mark up screenshot for a quick look at the interface and what some of the settings mean.
-Download the blender file below, I have it setup and ready to go.
If you like this and feel comfortable using it, we can get into some more complex editing. Like rendering passes, masks and how to bring them in and composite them together.
Please post some screenshots you have made or even better, a turnable animation.
Happy rendering and compositing,
Chad
JeffM
Johnjoti
You both are welcome. Looks like a whole 4 people are going to try it out. :D
That's 3 more than I thought would. This little bit you see is only the tip of the iceberg. ;)
JeffM
I'll give this a try. I've mess around with blender a bit, it is pretty cool :)
Does this work with exr, so that you have 32 bit data?
#5
Good question, I'm not sure at the moment though. It will export in the exr format, I would think it would import as well.
Please post what you end up with.  :)
JeffM
Oh yes, exr and tiff 32 bit work nicely with this method.
The 32 bit data from these formats allows you to control the threshold for the streaks much more precisely.
This image, started with a tiff32 render from KS, has the threshold up to about 100. I kept pushing the threshold up to around 500 to finally get above the light range of this image (I purposefully rendered it with really bright bright points in the factory environment)
This is the same render, first converted to an 8 bit jpg then put through the Blender.
In 8 bit images white is white and there's no data beyond that, compared to the 32 bit where there are exposure values saved beyond what is seen as white and what is seen as black. In 8 bit images you stay in the 0-1 threshold range in Blender.
Here's a more evenly lit environment. I added a little extra fog glow effect as well.
Thanks again for posting this Cholton, it's a great simple way to use Blender!
I'll have to set up a turntable next with a nice full model :)
These look great, Jeff!  :o Nicely done with the 32 bit data!!!
I'm anxiously awaiting the turntable.
Tip for anyone interested in rendering diamonds alone - Most environments have light colored grounds, you may want to consider adding a plane to place under your diamond and "paint it black" (newbies - changing the background color will not do this). If you don't you may end up with a washed out or "dirty" diamond.
Ed
Excellent post Chad - I'm going to give it a try.  Looks much more realistic than the Photoshop filters I've seen.
Would be nice to have a "Glare Filter" built into Keyshot :)
Ed
Thanks, Ed!  :)
Thanks to Jeff - the TIFF or EXR looks like the definite way to go when trying to create flares.
Hopefully more "how to's" to come!
#11
I couldn't resist redoing one of my original diamond turntable in the EXR format. I'll admit now that I got carried away with the glare...
Johnjoti
Looks very impressive
I like it:)
What is a filter applied for  multicolored flares?
my diamond
http://www.youtube.com/watch?v=qiC_L-PZ0cs
Strange. Flares were visible.
Now on Youtube, they are not visible  :-\
JeffM
The multi color comes from the color of the bright pixels the filter is working from. The dispersion in the rendering is helping get that color in those areas.
JeffM
Quote from: cholton on February 01, 2011, 08:00:52 PM
Only a little carried away  :) but very cool!
