Black render result in larger screen resolutions
Started by Duael, April 04, 2017, 06:48:01 AM
Duael
New user here.
When I attempt to use the higher predefined image pixel resolution settings for renders (anything above 4000 approx) I get a Black screen result in the render window. If I select a lower predefined setting, I will see my render result. If I then attempt to enter my own image resolution values, I get the same results. Black screen above 4k, visible image below 4k.
Any helpful suggestions would be appreciated.
Thank you
iMac, core i7, OSX 10.8.5, ZBrush Bridge. Keyshot 6.3.23
