Solidworks 2011 Error
Started by jasonleecooper, February 01, 2011, 05:13:23 PM
jasonleecooper
Series error after updating to KS 2.046 - Solidworks 2011 part/assembly files:
"does not contain 3d geometry.
You may need to export data from your modelling system."
Is this known yet and is there a fix?
It is supported in 2.2 - beta links are in the members only area.
jasonleecooper
Thomas - thanks for the speedy reply and pointing me to 2.2 update.
If, for whatever reason, some SW2011 have not updated their KS then saving SW2011 part/assembly files as .ProE does the trick as a workaround.
KS 2.2 feedback:
Like the new clean format - appears to open part/assembly files extremely quickly - all folders with contents updated - mapping seems more user friendly
Appreciated!  ;D
Good suggestion!! Thanks for the kind words as well.
