transparency on Keyshot for Zbrush
Started by mo, April 20, 2017, 10:15:44 AM
mo
Hi, I wanted to use transparency on objects, and found this tutorial.
https://www.youtube.com/watch?v=H7mwLIoiKrY
but the thing is that I can't find 'setting' tab in my Keyshot for Zbrush.
Is it just not there in Keyshot for zbrush??
I attached image what I'm looking for.
Thanks!!
Currently I'm not sure about the right version, but I think this was KeyShot 3.x. The quick tip is about global illumination to allow the light travel through an object with transparent material. You'll find this option in the lighting tab. And don't forget to set the indirect reflection to 1 or higher.
Hope that helps.
mo
