Blackout
Started by tvanryn, February 04, 2011, 09:56:46 AM
tvanryn
I just thought you'd all like to see this render.  I think the only non-custom material is the glass.  Critique away!
JeffM
Very nice!
I'd perhaps try rotating the environment to not get such a blown out white spot on the top.
One of the reflector cup normal maps added as a bumpmap (enable normal map mode) to the side reflector behind the rear wheel (if that's what it's supposed to be) might be nice instead of the perfect reflections you're getting now.
Looks great! That is one sweet ride. Did you model this?
I would like to critique the whole brake assembly. It needs to stand out a little less.. except the brake disc which should be a little more metallic with a slight circular bump.
tvanryn
Yes, that's all mine...except for the brake system!  That's actually the carbon ceramic Brembo system from the Corvette ZR1.  That model is direct from GM.
For more info on the car, along with a lot of renders of earlier versions, go to www.gtr-xs.com.  Some of the performance goals may seem a little ambitious, but remember, this car has 2000+ BHP!
Gordon Lardi
this car is hot, props!! :o
