Author Topic: HQ HDRI ENVIORNMENTS  (Read 208914 times)
« on: March 13, 2010, 12:50:57 pm »
Most of them are well known links...but still want to share....enjoy...
HOT...
http://www.openfootage.net/
OK
http://www.3dm3.com/forum/f123/want-download-free-hdri-5985/
http://www.hyperfocaldesign.com/hdri/hdr-environment-maps.html
http://www.doschdesign.com/products/hdri/
also recentely i have added my hdri collection..total 180 images ...n its free of course...go here
http://www.2shared.com/file/snEfv5tv/360.html
« Last Edit: June 12, 2010, 11:31:26 am by pinkpanther1234 »
Offline itc
Re: HQ HDRI ENVIORNMENTS
« Reply #1 on: March 26, 2010, 01:16:27 pm »
Thanks for the links! They are amazing!
Offline nomeradona
« Reply #2 on: April 18, 2010, 05:29:40 am »
my favorite...and they are free
http://www.hdrlabs.com/sibl/archive.html
Offline Ballista
« Reply #3 on: April 21, 2010, 05:08:46 pm »
Heres another with some nice HDRI's particuly medow trail
www.hdrmill.com/Freebies.htm
Offline Ralf-S
« Reply #5 on: May 06, 2010, 06:48:28 pm »
Thank you !
Downloaded all without problems.
Please take a look and follow this link: HDRI Environments
« Last Edit: May 13, 2010, 04:39:14 am by Ralf-S »
Offline David
« Reply #6 on: May 20, 2010, 09:00:11 am »
for all those photoworks converts dont forget all the old HDR data that came with the old installs.
David
Offline stef
« Reply #7 on: August 05, 2010, 04:53:16 am »
hy and thanks clearly the beauty of this program is the realistic look into an environment, without tomany setting, but clearly keyshot need to provide more 360 FREE  ;) hdr environment... like may other engline programs supply materials preset etc.. thankstef and great easy program!
Offline jhiker
« Reply #8 on: September 29, 2010, 04:12:37 am »
Some of these have a JPEG which I assume is a 'backplate' image and they often come with two hdr files - an '_Env.hdr' and a '_Ref.hdr' which is usually much bigger file size. What's the difference in the two hdr files please??
Offline Robert V.
« Reply #9 on: September 29, 2010, 10:48:02 am »
The bigger one is high-res, and results in sharp reflections. It can also be used for a render without a backplate.
+ Gives exact reflections
- Renders slower
The smaller one gives the correct lightening,
+ it renders faster
- no "real reflections"
« Reply #10 on: September 30, 2010, 07:15:29 am »
@PredatorKS - I don't think that HDR size has an effect on render performance once it is loaded.
Offline Robert V.
« Reply #11 on: September 30, 2010, 09:43:45 am »
@Thomas,
That could be true, I haven't experienced it myself, but I read it somewhere else...
« Reply #12 on: September 30, 2010, 06:53:57 pm »
Yeah, maybe in other software ;-) - we will test it though.
Offline chippwalters
« Reply #13 on: October 02, 2010, 09:06:00 pm »
Many of the renderers out there now support multiple resolutions of HDRI. Please check out sIBL:
http://www.hdrlabs.com/sibl/index.html
The idea is you can use a low-rez hdri for for lighting, a middle-rez for reflections, and a hi-rez one for backgrounds, unless you are using a backplate.
sIBL has some really good tools for creating all of these HDRI's from a single image. On the site, they say how much faster a render will finish if it uses low-rez lighting maps.
Offline PeterSchmidt
« Reply #14 on: October 03, 2010, 12:41:15 am »
Your comment about speeding up when using low res maps for lighting does only apply to slow tools like mental ray, most near realtime engines do not need such tricks ... no need for sIBL.
