Multiple labels
Started by cheltenhamboy, February 14, 2011, 04:33:31 AM
cheltenhamboy
Don't know if this is something other users would like but -
I often have to apply the same label many times in the same scene. Currently the workflow goes like this: Select Add, navigate to the label image and select it, Position it initially, adjust Scale, Angle, Intensity etc and finally Position the adjusted image. To add the [same] label again it is currently necessary to repeat the entire procedure, carefully copying the settings before placing the label where required.
Would it be possible to provide a "repeat position" function whereby, by [say] holding down the Ctrl key while Position is selected, another label was placed with each click of the LMB? It would be especially helpful if each label repeated in this way appeared as though the Add button had been used (i.e. with its own label number). Also - how about implementing a copy label function in the same manner that a texture can be copied, by holding down shift, copying with LMB and pasting with RMB?
Labels are soooo useful!  ::)
