6.3.23 Freezes on mesh texture application
Started by boycee41, May 22, 2017, 12:19:24 PM
boycee41
I have an annoying issue, when I drag the metal texture "horizontal mesh 1" onto an object, the screen locks up at the hold Alt to retain textures etc  notification, I can access the top menus, which pull down, but can't click on anything without a full crash occurring. This happens even on the cube in added geometry, other mesh textures seem to be ok, just the horizontal ones, even in different finishes, same result. If I open the same scene on my Surface Pro, same version of Keyshot, same OS etc, it works ok, CPU is intel i7, on the Surface, and AMD FX9590 on main system, also does the same on the AMD 8350 system I have. Help !!
Do you have licenses for KeyShot on all of these machines? Or are you moving the license?
