Author Topic: How to make a toon look like this?  (Read 8879 times)
Offline melnation.com
« on: May 27, 2017, 12:48:08 pm »
https://youtu.be/6Tm3yQHrqbE
I already saw the downloadable toon materials from the website, specifically three of them, but they're no where near look like this
Thanks Gracias Arigato Buenas Noches!
Re: How to make a toon look like this?
« Reply #1 on: October 16, 2017, 06:35:39 am »
Definitely one of the most useless 'community' I've ever seen in terms of quality of help provided
« Reply #2 on: October 16, 2017, 06:46:16 am »
With that sort of attitude it will probably stay that way for you.
Regardless, with a 10 second google search I came up with a plethora of options. A lot of times getting the results you are looking for is a lot of trial and error, not someone telling you what buttons to push.
https://blog.keyshot.com/2016/using-keyshot-toon-material-technical-illustration
https://www.youtube.com/watch?v=U45T32qtu4s
https://www.youtube.com/watch?v=aFpJ7NzNjY4
https://www.keyshot.com/forum/index.php?topic=9174.0
While none of these might answer your question directly, you might get some ideas to work with to get the look you want.
That all being said, it is unusual that posts are not responded to. The rate of Luxion people responding to questions is one of the highest participation rates of any software forums I've ever seen.
Good luck!
Offline DriesV
  • Administrator
  • Total likes: 81
« Reply #3 on: October 20, 2017, 01:53:41 am »
Rudeness has never been a good strategy to get help. ;)
Anyway...
You can match this result in KeyShot by using the Toon material, as Matt suggested in the post above.
The trick for getting the "cel shading" is to turn on the 'Environment Shadows' option in the Toon material and use an HDRI with a very small Pin light on a black background. You will want to set the Shadow color of the Toon material to a slightly darker version of the Color.
As Matt also said, experimentation is key. There is no fixed recipe.
I have made a sample scene in KeyShot 7. I went "all in" and made extensive use of the Material Graph, so you may want to view this in KeyShot 7 Pro (or a full trial). All materials are Toon.
Download here.
I used this great "Jet Drone" model from GrabCAD.
I hope this helps.
« Last Edit: October 20, 2017, 05:16:11 am by DriesV »
Offline DriesV
  • Administrator
  • Total likes: 81
« Reply #4 on: October 20, 2017, 02:01:00 am »
note: You can change the 'Default Color' in the 'Vertex Color' node (labeled 'BASE COLOR') to make quick color variations.
For this image I just changed the BASE COLOR nodes.
« Last Edit: October 20, 2017, 02:10:20 am by DriesV »
Offline DriesV
  • Administrator
  • Total likes: 81
« Reply #5 on: October 20, 2017, 04:49:42 am »
Can't stop tweaking this... :P
Offline Robb63
« Reply #6 on: October 20, 2017, 05:01:39 am »
Hey DriesV,
I tried to download the two zip files (I was dying to play with this), and they won't unzip. I've downloaded them several times, and they fail each time. Any chance you can upload them again? They look like fun to experiment with.
Offline Esben Oxholm
« Reply #7 on: October 20, 2017, 05:13:00 am »
Nice results, Dries!
Offline DriesV
  • Administrator
  • Total likes: 81
« Reply #8 on: October 20, 2017, 05:13:09 am »
Hmm, it worked fine for me with 7-Zip. ???
I have  uploaded the bip file to my Google Drive now and put the link in my first post.
I hope that works for you. :)
Offline Robb63
« Reply #9 on: October 20, 2017, 08:36:15 am »
Excellent!! Thanks for reposting the bip
Offline DMerz III
« Reply #10 on: October 20, 2017, 01:03:56 pm »
Awesome! Great example, Dries
