2.2.42 Is Overwriting Renders in Que (Pro version)
Started by Robb63, February 23, 2011, 11:24:39 AM
Robb63
Just rendered ten renderings, only had one if my render folder.
Ran it again on two renders in the que to test and watched this time.
Only the last image to render is in the render folder when it finishes. They are saving as .tifs
Alex
I made the same experience with the latest update. Could I restore the version before? I have to render a lot of pictures for the next two days...  :-[
Fixed in the latest update - do a "Check for Updates" under the Help menu.
Alex
Sorry, Thomas, but "No new version were found" is the response from the check for updates. I just tried it several times.
AxelRod
confirmed.  I updated to 2.2.43 using the check for update.  It works now.  Thank you!
Alex
 :o sorry, but my version doesn't find an update...  :-[
Alex
