Author Topic: 2.2.42 Is Overwriting Renders in Que (Pro version)  (Read 5314 times)
Offline Robb63
« on: February 23, 2011, 11:24:39 am »
Just rendered ten renderings, only had one if my render folder.
Ran it again on two renders in the que to test and watched this time.
Only the last image to render is in the render folder when it finishes. They are saving as .tifs
Re: 2.2.42 Is Overwriting Renders in Que (Pro version)
« Reply #1 on: February 23, 2011, 03:02:06 pm »
We will check into this.
Offline Alex
« Reply #2 on: February 25, 2011, 01:58:09 am »
I made the same experience with the latest update. Could I restore the version before? I have to render a lot of pictures for the next two days...  :-[
Offline AxelRod
« Reply #3 on: February 25, 2011, 08:39:04 am »
+1
« Reply #4 on: February 25, 2011, 08:56:13 am »
Fixed in the latest update - do a "Check for Updates" under the Help menu.
Offline Alex
« Reply #5 on: February 25, 2011, 09:04:14 am »
Sorry, Thomas, but "No new version were found" is the response from the check for updates. I just tried it several times.
« Reply #6 on: February 25, 2011, 09:06:41 am »
Ok - we will make it live shortly.
Offline AxelRod
« Reply #7 on: February 25, 2011, 09:07:53 am »
confirmed.  I updated to 2.2.43 using the check for update.  It works now.  Thank you!
Offline Alex
« Reply #8 on: February 25, 2011, 09:16:29 am »
 :o sorry, but my version doesn't find an update...  :-[
« Reply #9 on: February 25, 2011, 11:33:18 am »
Works now.
Offline Alex
« Reply #10 on: February 26, 2011, 02:53:01 am »
Updated and works fine. Thanks!
