Large Tiff file size after 2.2.42 update
Started by Stuby, February 24, 2011, 02:54:22 AM
Stuby
I have just completed the V2.2.42 update and re rendered an older image, the Tiff file size has increased 10 fold, can anyone help or make suggestion? :(
Abigail111
Hi there
If the tiff file size was increased ,you can try to compress the tiff files size to satisfy your size.You said that this problem appeared after you updating.I'd like to suggest you reinstall this tiff program.
Or you maybe had to change another program.Best wishes.
lucywill
use a .net tiff application to compress tiff file is actually a good method, what tiff compression solution do you suggest, better be lossless? thanks
