Author Topic: Extruded Aluminium  (Read 9909 times)
Offline PhilippeV8
Extruded Aluminium
« on: March 03, 2011, 01:57:20 am »
I'm searching for a material for extruded aluminium profiles which doesn't kill my render-time.
I've tried some of the metal materials in the library but can't find anything that works for me.  Anyone has some tips ?
I got one now with Anisotropic
Diffuse ( 59:59:59 )
Specular ( pure white )
RoughX 0,010
RoughY 0,090
Angle 0
Mode 1
Glossy samples 3
I also added a bumpmap with extrusion lines, but when I render with this turned on the texture becomes grainy.
I'm quite happy with this one, though it renders slooow and I have to turn off the extrusion lines.
Offline PhilippeV8
Re: Extruded Aluminium
« Reply #1 on: March 03, 2011, 02:02:23 am »
What is also important, is that if you got an extruded (e.g. squared) tube, the inside of the tube must not be black ... it still needs to show a gradient from the outside inwards and you have to have the corners visible.
Offline PhilippeV8
« Reply #2 on: April 20, 2011, 04:50:50 am »
I think I have found a solution to this adding a tiled semi-transparent lable to the material .. need to work on it further.
Offline Richman
« Reply #3 on: April 20, 2011, 11:13:45 pm »
Can you show us some images??
Offline PhilippeV8
« Reply #4 on: April 21, 2011, 02:04:12 am »
I am rendering them ... but it turns out that my current material takes a loooooooooooooooooooooooooooong time to render :(
Offline PhilippeV8
« Reply #5 on: April 21, 2011, 04:14:28 am »
Here are the renders ..
The first is the profile with default material ... I want the inside of the squared tube to be visible just like this.
The second is just default chrome .. I want the outside to look like this though less clean and with scratch marks from the extrusion.
The final render is what I got now and what I waited looooong time to render ... As you can see, it's not perfect yet .. not at all.
It's got weird groves near the front and I don't like the part inside the partly open cavety.
Offline PhilippeV8
« Reply #6 on: April 21, 2011, 06:30:26 am »
I think this one is getting real close ...
  • Guest
« Reply #7 on: April 21, 2011, 07:14:42 am »
The last one is great.
Offline justindustrial
« Reply #8 on: May 23, 2011, 03:26:49 am »
The 'metal' material renders quickly, maybe you could try that with a roughness of 0.2 or something, give it a warm aluminum colour and add a planar bumpmap for your extrusion lines? Don't forget to crank up glossy samples.
