render overbright on Queue using real-time frames
Started by andy.engelkemier, March 15, 2011, 11:04:32 AM
andy.engelkemier
I queued up 5 renders, nearly all the same.
I told it to process the queue and it came out Way over bright.
I deleted all that's in the queue and without changing the file started rendering using the exact same settings one by one. The downside is I have to be around now for a few hours to make sure and queue the next one manually.
Any idea when this might be fixed? it's pretty much the main reason we purchased Pro.
andy.engelkemier
sorry yes. I'm still working on it too. I don't trust the queue now.  :-\
Rendering with the Queue it was overbright, the same file without it, no problems.
eric
I never managed to render anything at a decent resolution in "good" quality using the render cue.
Reasons we bought PRO is for rendering a cue overnight and sometimes render single pictures at higher resolutions.
This is not reliable at all. When I come back in the morning my tifs are completely black or white.
It starts to render and stops after a while for some reason.
I have 8GB memory on a dual Quad core Xeon Dell R5400.
When I render these separately it works.
eric
I am not talking about effects - I am talking about the render mode - offline or realtime?
eric
Realtime render always works.
I'm talking about hitting the render button.
Isn't this the same as the renderer for the cue?
