Number of decimal places
Started by kevinkoller, March 17, 2011, 04:21:16 PM
kevinkoller
The number of decimal in the options input boxes is limited to 3.  When I am trying to make fine adjustments, often times 3 decimal places is not quite enough.  Is there any reason that I am prohibited from being more precise if I need to be?
I would suggest increasing the limit on number of places to 5 or 6.
PhilippeV8
+1
However, if you use the "move/scale" tool you can do minor adjustments that don't even show up in the number-box.  Only downside is that often you gotta zoom in quite a lot to do the exact positioning and since the .. what's it called .. "the thing with the arrows for moving objects" ... can't be repositioned ...
This might be a good addition too ... add a toggle-box for moving "thingy" with object / move "thingy" alone
PhilippeV8
"MOVE WIDGET" ... !!  That's the one ;)  Widget .. thingy .. that's the same either way ;p
