1 Hour
1 Day
1 Week
1 Month
Forever
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Help
Search
Login
Register
KeyShot Forum
Technical discussions
Data Import
Poor curve resolution
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Poor curve resolution (Read 19347 times)
bointon
Newbie
Total likes: 0
Re: Poor curve resolution
Reply #15 on:
January 23, 2014, 03:42:12 am »
I am also struggling with this. Image here shows a facetted curve which I cannot smooth out.
Its one for Keyshot and Solid Edge to resolve.
Logged
thomasteger
Guest
Reply #16 on:
January 23, 2014, 05:09:37 am »
If you are running ST6, then you should use the free plugin.
For ST5, you may want to use the KeyShot export from Solid Edge - see attached images.
Logged
bointon
Newbie
Total likes: 0
Reply #17 on:
January 26, 2014, 11:54:46 pm »
Hi Thomas, I'm using ST6. where do I find this free plug in?
Logged
thomasteger
Guest
Reply #18 on:
January 27, 2014, 06:15:15 am »
It is in the Solid Edge load point and here:
keyshot.com/plugins
Logged
bointon
Newbie
Total likes: 0
Reply #19 on:
January 27, 2014, 06:24:01 am »
Thanks Thomas, I found this plug in and ran it, but the Add In doesn't appear in the Solid Edge Add In list. When I run the update icon in Solid Edge it tells me "Keyshot Live Linking must be running" Any clues?
Logged
thomasteger
Guest
Reply #20 on:
January 27, 2014, 08:39:59 am »
Make sure that Live Linking is enabled in KeyShot (under the file menu). Also make sure that you are running KeyShot 4.
Logged
bointon
Newbie
Total likes: 0
Reply #21 on:
January 27, 2014, 10:58:50 pm »
I'm running Keyshot 4.3.10 and live linking is ticked in the file menu but still no joy?
Logged
jeffw
Full Member
Total likes: 0
Reply #22 on:
January 28, 2014, 04:54:19 am »
You seem to be talking about two different problems. One with curve resolution and one with live linking. You don't need live linking to open a .bip file produced from SolidEdge which should deal with the faceting problem with or without live linking.
Thomas, this is a great fix. Thanks.
Logged
bointon
Newbie
Total likes: 0
Reply #23 on:
January 28, 2014, 10:55:21 pm »
I got there in the end - thanks guys. Used the save as Translated option. Still cannot get the live linking to work though!
Logged
thomasteger
Guest
Reply #24 on:
January 29, 2014, 05:36:27 am »
You will need to contact GTAC for help with the plugin.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
KeyShot Forum
Data Import
