Pro/E Plugin - now supporting Wildfire 2, 3, 4, and 5
Started by guest84672, March 26, 2010, 08:15:15 AM
We finally have the Pro/E plugin ready for you. The plugin supports Pro/ENGINEER WF 2, 3, 4, and 5, and can be downloaded here:
32bit: www.keyshot.com/install/ProE_Plugin_32.zip
64bit: www.keyshot.com/install/ProE_Plugin_64.zip
NOTE: Make sure you are running a 64bit OS, Pro/E 64bit, and KeyShot 64bit.
How it works: After installing the plugin you will have a "KeyShot" button directly inside of Pro/E. Simply load your model, then hit "KeyShot" in the top menu bar.
The dialog that appears will ask you to select the "up" vector, and the tessellation quality. The lower the number, the more polygons you will get.
Hit Render.
The Pro/E menu manager appears to prompt you to select any representation if present. Select it, hit done.
KeyShot will start, and your Pro/E model will be transferred.
Thomas
