Rhino importer and KS 2.2.65
Started by Johnjoti, April 23, 2011, 04:49:42 AM
Johnjoti
Hi KS team!
I think that the Rhino importer is not finalized
still appear jagged on the reflections
thanks
This has nothing to do with the importer itself. All we do is read the tessellated information from the Rhino file.
Robert V.
Is the jagging not created by the HDRI itself?
Johnjoti
#3
I already wrote a lot about it
It is not associated with tessellation
http://keyshot.com/forum/index.php?topic=1414.15
Quote from: Johnjoti on March 10, 2011, 04:46:26 PM
Here render from the Rino
Here I imported the same storage geometry from the bip file (from Rhino) into a new project
I attached the file that generated when rendering from the Rhino
You can import geometry from this bip file to a new type file
and make sure that jaggies are formed is not associated with tessellation inside Rhino.
Use standard HDRi "HDRLightStudio_car_studio_medium"
Jhon G
Johnjoti
Hi
I want to ask
Is it possible to render a KeyShot from the Rhino 5.0 x64 ?
You mean importer or plugin? Importer works., not sure about plugin. Should work too.
Johnjoti
Missed the 64bit part. No it will not work. SDK is not yet available.
Johnjoti
