Importing SW17 Files Into KeyShot 6.3 Coming In Blank
Started by exactrawr, June 27, 2017, 01:05:58 PM
exactrawr
Hi all,
I am using SW17 with KeyShot 6.3 and running into a problems when I try and import my assembly file into KeyShot.
When I import my assembly file, the KeyShot file appears with the SW part in the assembly tree but without any geometry at all. If I use the SW plugin to import the file it comes in as expected.
The reason I want to use a manual import is because I need to uncheck the 'Separate Materials by Part' option or my mapping does not work correctly for my surfaces.
Any help would be greatly appreciated.
