Lines of light?
Started by melvinraju, August 03, 2017, 02:02:54 PM
melvinraju
can someone tell me why there are block/lines of light coming down my model.
any fixes?
LayC42
Hello Melvin
Sorry - I have no idea what do you mean and how I can help you.
Perhaps add some marks on your render, so we can see what's wrong?!
If I understand correctly, it looks like this is a tessellation issue. Try increasing the tessellation value upon import. You can also try right-clicking on the part and selecting 'edit geometry', then try the edit normals option. Next, click 'calculate normals', then accept the changes and see if it looks better.
Quote from: Will Gibbons on August 04, 2017, 06:51:58 AM
The calculate normals trick works most of the time for my imported models. I wish there was a quick and easy way to do that globally instead of part by part, maybe be able to do the operation to a group. That would be fantastic.
Quote from: mattjgerard on August 04, 2017, 09:05:43 AM
Me too. It should be able to be done upon import using the import options if I'm not mistaken.
Quote from: Will Gibbons on August 07, 2017, 07:40:40 AM
Aww dang, I'll have to check that out!
melvinraju
hi i cant find an edit geometry button im using keyshot 5.0 pro
richardfunnell
KeyShot 5 does not have the ability to edit geometry, this feature is in KeyShot 6/7.
