Author Topic: Transferring animations from keyshot 6 to 7  (Read 1815 times)
Offline Maxwell94
« on: August 05, 2017, 10:58:48 pm »
I am trying to open an animation made in keyshot 6 in keyshot 7 to be able to export the camera data, but the camera movements get jumbled up upon the transfer. The model movement are unaffected however. Just wonder if there is a way to fix the camera movements without completely recreating them?
  • Guest
Re: Transferring animations from keyshot 6 to 7
« Reply #1 on: August 07, 2017, 06:50:08 am »
Do you have an example that you can share?
Offline Rex
« Reply #2 on: August 07, 2017, 04:01:01 pm »
Can you be a bit more specific about your process? Are you simply opening a KeyShot 6 .bip file in KeyShot 7? Then when you scrub through the timeline in 7 the camera animation behaves differently?
