Pb with spot lightings
Started by seblezinzin, April 30, 2011, 07:19:25 AM
seblezinzin
Hello everybody,
I try rendering with the new emissiv material, but on my render, I have many tasks on hull.
I use the spot light material, white color, and intensity of 3000. On the picture, you could see all rendering parameters
To delete this problem i tried an other emissiv material, reduce noise and rugosity on hull material (plastic)
What's the solution??
seblezinzin
I suggest you use the realtime render mode. You can find this option in the render tab inside the render menu.
